8 years agopragma unroll breaks kernel
Hi, I'm trying to figure out why my kernel breaks when I try to use the #pragma unroll statement for a loop. I'm using the 16.1 SDK and the device I'm running on is an Arria 10/DE5a-net and co...
8 years ago --- Quote Start --- I'm using the 16.1 BSP on Linux which is the newest one. Why is it broken? Do you have a reference? And should I use the 16.0 instead? --- Quote End --- Broken as in kernels fail to compile due to some mismatch between the synthesized IP cores in the BSP and Quartus. Though I just tired it on Quartus 16.1.2; maybe it works on 16.1.0. Anyway, if your kernels compile correctly, you don't need to worry about it. Just wanted to ask since other people in the forum had previously reported compilation failure with this BSP.
