8 years ago#pragma ivdep seems not work
Hello, I have a opencl kernel, like this: kernel void test() { float array[100]; # pragma ivdep do { chann_data addr = read_channel_altera...
8 years agoThanks for your reply! I am certain that addresses addr1 and addr2 never overlap, and the opencl version is 16.0.
But in the Intel FPGA for OpenCL Best Practices Guide, I see "The array specified by the ivdep pragma must be a local or private memory array, or a pointer variable that points to a global, local, or private memory storage. If the specified array is a pointer, the ivdep pragma also applies to all arrays that may alias with specified pointer." So, I think "Pragma unroll" can work on local memory? Is right? Thank you!
