9 years ago#pragma ivdep not allowing for parallel stores to local memory
Hello, I am having difficulty in parallelizing local memory store operations and would appreciate help. The load from local memory appears to be parallelized however in the report.html's Syste...
9 years agoThank you for your reply HRZ.
Eventually I ended up figuring out a way to rewrite my algorithm to use banking. On the System View section of the compiler report I now see parallel loads/stores however I still see a couple of minor strange store dependencies within what appears to be a section of the code that's contained to operate on a single bank. I'm guessing because in my code I'm writing to two values to the same bank even though I have set the numwriteports to 2. I understand what the original issue was but after revisiting the Best Practices Guide, it seems Altera/Intel suggest ivdep should be applicable to local memory. From the guide: "The array specified by the ivdep pragma must be a local or private memory array, or a pointer variable that points to a global, local, or private memory storage." It seems like the ivdep applied to local memory could be useful for my original situation - where the array access is indirect or complex but the user knows there won't be bank collisions. Thanks for your help again.
