9 years agoPowerplay Result
Hi,I have generated a .vcd file and insert it into the Powerplay Power Analyzer Tool in Quartus II 11.0,and get the result as follow. I think the dynamic power is too small. IS THIS RESULT CORRECT? ...
9 years ago --- Quote Start --- Hello, From waht I read, I think Quartus does not have enough info to conclude anything. In the SDC file you might need to update/correct your clock timing constraints. Best Regards, Johi. --- Quote End --- Thanks for your reply. And can you tell me how can I set timing constraints? Is it be set in the timequest in Quatrus timing analyzer? Thanks sincerely.
