10 years agoPowerPlay estimation and asynchronous faster-than-clock signal: no clock domain found
Hi all, I am a newbie and I have a simple task at hand. I am working on a simple controller project on a Max3000A series device with an input signal that is faster than the system clock....
10 years agoI think your design is too small for too much concern on logic accurate transition rate as most of power would be static (as opposed to that of switching).
If you indeed want proper rate you need to look at your simulation for sometime and estimate toggle rate per signal. But it is overkill and I suggest using default of 12.5% for io and all signals. Try then increase it and you will see the difference to be small anyway
