10 years agoPowerPlay estimation and asynchronous faster-than-clock signal: no clock domain found
Hi all, I am a newbie and I have a simple task at hand. I am working on a simple controller project on a Max3000A series device with an input signal that is faster than the system clock....
10 years agoThank you kaz for being helpful.
I must apologize for I failed to mention that my project is basically a control system experiment of a simple process. It is made up of a Finite State Machine only (with exception of the async signal I mentioned earlier, which is the only signal that is not a part of the FSM). --- Quote Start --- Since your design is just few signals you can enter overall toggle rate. --- Quote End --- With the toggling of the state flipflops being absolutely dependent on events occuring in the process and its previous state, the toggle rate, to me, seems indeterminable. I am saying this because I can't ascertain what state the flipflops will transition to and when the transition will occur since it is dependent on real-world inputs. The flipflops will maintain a certain value (say "0101") for as long as an event that triggers a transition to another state does not occur, and when an event occurs, it may transition to, say "1111" or "1011" or "1010" or ..., depending on what event occurred. I think you can guide me better if I paste my code so you take a look at it.LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.all;
LIBRARY altera_mf; USE altera_mf.altera_mf_components.ALL;
ENTITY MBHPCP_State_Controller_with_MAX3000A_for_test IS
PORT (clk, ok, enough, before, beyond : IN STD_LOGIC := '1';
mode_switch, reset, silence_switch, alarm_pulse, buzzer_astable : IN STD_LOGIC := '0';
trouble_buzzer, trouble_LED, auto_mode_LED,
enough_LED, before_LED, beyond_LED, not_ok_LED, silence_LED : OUT STD_LOGIC := '0';.
roll : BUFFER STD_LOGIC := '0');
END ENTITY MBHPCP_State_Controller_with_MAX3000A_for_test;
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; USE IEEE.NUMERIC_STD.ALL;
ARCHITECTURE behaviour OF MBHPCP_State_Controller_with_MAX3000A_for_test IS
CONSTANT reset_state : STD_LOGIC_VECTOR(2 DOWNTO 0) := "000";
CONSTANT stop_roll_state : STD_LOGIC_VECTOR(2 DOWNTO 0) := "011";
CONSTANT roll_state : STD_LOGIC_VECTOR(2 DOWNTO 0) := "110";
CONSTANT trouble_state : STD_LOGIC_VECTOR(2 DOWNTO 0) := "111";
CONSTANT silent_state : STD_LOGIC_VECTOR(2 DOWNTO 0) := "101";
SIGNAL state : STD_LOGIC_VECTOR(2 DOWNTO 0) := reset_state;
CONSTANT auto : STD_LOGIC := '0';
SIGNAL alarm_snooze_timer : STD_LOGIC_VECTOR(0 TO 12) := "0000000000000";
SIGNAL roll_starting_time_delay : STD_LOGIC_VECTOR(0 TO 2) := "000";
SIGNAL silence_to_trouble : STD_LOGIC := '0';
BEGIN
-- GENERATION OF LED INDICATION FOR THE STATUS OF THE RESPECTIVE PROCESS INPUTS BEGINS FROM HERE.
before_LED <= '1' WHEN before = '0' ELSE '0';
enough_LED <= '1' WHEN enough = '0' ELSE '0';
beyond_LED <= '1' WHEN beyond = '0' ELSE '0';
auto_mode_LED <= '1' WHEN mode_switch = auto ELSE '0';
not_ok_LED <= '1' WHEN ok = '0' ELSE '0';
-- GENERATION OF LED INDICATION FOR THE STATUS OF THE RESPECTIVE PROCESS INPUTS ENDS HERE.
-- GENERATION OF ALARM_SNOOZE_TIMER_GENERATOR FOR TROUBLE_BUZZER SNOOZING BEGINS HERE.
alarm_snooze_timer_generator : PROCESS (clk)
BEGIN
IF clk'EVENT AND clk = '1' THEN
IF alarm_pulse = '1' THEN
IF mode_switch = auto THEN
IF state = silent_state AND alarm_snooze_timer = "1111111111111" THEN
silence_to_trouble <= '1';
alarm_snooze_timer <= "0000000000000";
ELSIF state = silent_state AND alarm_snooze_timer < "1111111111111" THEN
alarm_snooze_timer <= alarm_snooze_timer + 1;
ELSE
END IF;
IF state /= silent_state THEN
silence_to_trouble <= '0';
END IF;
END IF;
END IF;
END IF;
END PROCESS;
roll_starting_time_delay_generator : PROCESS (clk)
BEGIN
IF state = roll_state AND ok = '1' AND roll_starting_time_delay = "111" THEN
roll_starting_time_delay <= roll_starting_time_delay;
roll <= '1';
ELSIF state = roll_state AND ok = '1' AND roll_starting_time_delay < "111" THEN
roll_starting_time_delay <= roll_starting_time_delay + 1;
roll <= '0';
ELSIF state /= roll_state OR ok = '0' THEN
roll_starting_time_delay <= "000";
roll <= '0';
END IF;
END IF;
END IF;
END PROCESS;
-- GENERATION OF ROLL_STARTING_TIME_DELAY_GENERATOR FOR TROUBLE_BUZZER SNOOZING OF ABOUT 8 SECONDS ENDS HERE.
-- GENERATION OF FINITE STATE MACHINE FOR RESPECTIVE STATE TRANSITIONS BEGINS FROM HERE
finite_state_machine_generator : PROCESS (clk)
BEGIN
IF (clk'EVENT AND clk = '1') THEN
CASE state IS
WHEN reset_state =>
IF (before = '0' AND enough = '0') OR (beyond = '0') THEN
state <= trouble_state;
ELSE
IF (enough = '0') THEN
state <= stop_roll_state;
END IF;
IF (before = '0') THEN
state <= roll_state;
END IF;
END IF;
WHEN stop_roll_state =>
ELSIF (before = '0' AND enough = '1' AND beyond = '1') THEN
ELSE
END IF;
WHEN roll_state =>
IF (before = '0' AND enough = '0') OR beyond = '0' THEN
ELSIF (before = '1' AND enough = '0' AND beyond = '1') THEN
ELSE
END IF;
WHEN trouble_state =>
IF (reset = '1' AND before = '1' AND enough = '1' AND beyond = '1') THEN
state <= reset_state;
ELSIF silence_switch = '1' THEN
state <= silent_state;
ELSE
END IF;
WHEN silent_state =>
ELSIF silence_to_trouble = '1' THEN
ELSE
END IF;
WHEN OTHERS =>
END CASE;
END IF;
END IF;
END PROCESS finite_state_machine_generator;
trouble_buzzer <= '1' WHEN ((state = trouble_state) AND (mode_switch = auto) AND (buzzer_astable='1')) ELSE '0';
trouble_LED <= '1' WHEN (state = trouble_state) ELSE '0';
silence_LED <= '1' WHEN state = silent_state ELSE '0';
-- GENERATION OF FINITE STATE MACHINE FOR RESPECTIVE STATE TRANSITIONS ENDS HERE
END ARCHITECTURE behaviour; --- Quote Start --- you can enter toggle rate in powerplay r I think yu can also enter in quartus project settings --- Quote End --- Please, how do I calculate the toggle rate in this scenario.
