Altera_ForumHonored Contributor14 years agoPowerPlay Early Power Estimator missing file error I downloaded the PowerPlay Early Power Estimator from Altera's web site. When I open the spreadsheet and enable the macros, I get the following error messsage: Permission error when loading ep...Show More
Altera_ForumHonored Contributor14 years agohave you seen this? http://www.altera.com/support/kdb/solutions/rd11142011_245.html
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
