DNLDNL
5 years agoPOWER_UP_LEVEL for Partial Reconfiguration
Hi.
I use dcfifo ip core which has POWER_UP_LEVEL assisment for some registers. Quartus shows warnings:
Critical Warning(19519): The instance assignment "POWER_UP_LEVEL" on register "...|rx_fifo...
sstrell
5 years agoThe built-in help says to simply remove the assignments:
Are you saying the IP added these assignments when you added it to your design? It seems like you can safely ignore this unless you have requirements for these registers after you perform a PR.
- DNLDNL5 years ago
This registers are part of FIFO Intel® FPGA IP(https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fifo.pdf)
Therefore I can't remove the assignments.
