11 years agoPowePlay. I/O power and core static power
I'm trying to understand how PowerPlay works. I use Quartus 10.1 sp1. I have two projects (A and B) that execute exactly the same task. These projects are implemented on the same F...
11 years agoStill digging into the report files.
I found a significant difference in th power dissipated by the ignal 'clk~inputclkctrl' indicated as a clock control block. Is there anybody that knows which is the function of this block/signal? I'm guessing that the circuit A thahas less FF dissiates less power on the clock signal w.r.t. circuit B. Everything would be fine ifthe power dissipated by the clock would be reported in some way as I/O power. What do you think?
