15 years ago --- Quote Start --- write: u1:and2 port map(....); not u1: entity... You don't need add sub entities code, just click add files in the project menu files. --- Quote End --- Thank you very much. You are a big helper. I had done it and it still have an error: I had made the video step by step which i had made. Could you down it and check for me where my problem. thank you again This is my error: --- Quote Start --- Error: Port "data0" does not exist in primitive "and2" of instance "U1" Error: Port "data1" does not exist in primitive "and2" of instance "U1" Error: Port "result" does not exist in primitive "and2" of instance "U1" --- Quote End --- This is my code:
library IEEE;
use work.all;
USE ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.lpm_components.all;
entity JKFF_TFF is
port (x,xp : In STD_LOGIC;
Z : Out STD_LOGIC;
clk : In STD_LOGIC);
end JKFF_TFF;
architecture structure of JKFF_TFF is
Component and2
PORT
data0 : IN STD_LOGIC ;
data1 : IN STD_LOGIC ;
result : OUT STD_LOGIC
end component;
component and3
PORT
data2 : IN STD_LOGIC ;
END component;
component or2
PORT
END component;
component or3
PORT
END component;
component or4
PORT
data3 : IN STD_LOGIC ;
END component;
component xor2
PORT
END component;
Signal a1,a2,a3,a4,a5,a6,a12,a13,a14,a15,a16,a17 : STD_LOGIC;
Signal Y0,Y1,Y2,Y3,Y4 : STD_LOGIC;
Signal Q0,Q0p,Q1,Q1p,Q2,Q2p: STD_LOGIC;
Begin
U1: and2 port map (x,Q1p,a1);
U2: and3 port map (x,Q2p,Q0p,a2);
U3: or2 port map (xp,Q2,a3);
U4: or3 port map (xp,Q2,Q1,a4);
U5: or3 port map (Q2p,Q1p,Q0,a5);
U6: or4 port map (x,Q2p,Q0p,a6);
U7: or2 port map (a1,a2,Y0);
U8: and2 port map (Q2,Q1,Y1);
U9: and2 port map (Q0,a3,Y2);
U10: or2 port map (Q0,Q2,Y3);
U11: and3 port map (a4,a5,a6,Y4);
U12: xor2 port map (Q2,Q1,a12);
U13: xor2 port map (Q2p,Q1,a13);
U14: and3 port map (a13,xp,Q0p,a14);
U15: and3 port map (Q1p,xp,Q0,a15);
U16: and3 port map (a12,x,Q0p,a16);
U17: and3 port map (Q1,x,Q0,a17);
U18: or4 port map (a14,a15,a16,a17,Z);
End structure;
This is link of my video "add sub entity file and delete sub entity from main entity" http://www.mediafire.com/?u58cjgxziq7rzn8
