15 years agoHi,
You may better infer AND by simply coding this instead of megawizard approach: y <= A and B; then the compiler will do the instantiation. If, however, your professor wants you instantiate then the rule is: add file to project, declare the component interface before port map after architecture but before begin. component AND2 port( data0 : in std_logic; ... ); end component; then use port map after begin as you have done. you should port map all three ports: u1:AND2 port map( );
