syam404
4 years agopolar IP frozen bits defining
Sir/madam,
1) In the example design of polar IP there is a polar5g_codec_parameter.txt, in that do we need to specify N frozen bits for every new parameters.
2)In that they are using different se...
Ash_R_Altera
4 years agoHi,
It is up to you how you want to drive DUT signal param_fro from testbench. Currently in testbench, it gets driven from the following line:
for (i=0; i<blocklen; i++) if (!$fscanf(paramfile, "%d", param_fro[i])) $display("DEBUG_1");
You can modify this and add your own logic there.
