11 years agoPLL simulation with Altera Modelsim starter edidtion
Hello, When I try to simulate Altera PLL generated with Megawizard using Altera Modelsim starter edition I am getting error message : (vlog-13006) Could not find the package (altera_lnsim_function...
11 years ago --- Quote Start --- Are you adding and compiling the right Altera library in ModelSim? You will need to add and compile the 'altera_mf.v' library, which comes as part of the Quartus installation. You'll find it under:
<quartus_install_path>/quartus/eda/sim_lib/altera_mf.v Cheers, Alex --- Quote End --- Alex, Thanks! Yes. I compiled the library. When I used Mentor's ModelSim/QuestaSim before I never had this kind of problem. This time I have to use the ModelSim Altera Starter edition and I am getting this issue. Thanks, -Mike
