11 years agoPLL simulation with Altera Modelsim starter edidtion
Hello, When I try to simulate Altera PLL generated with Megawizard using Altera Modelsim starter edition I am getting error message : (vlog-13006) Could not find the package (altera_lnsim_function...
11 years agoIf you use the .v file instead of the .vo file, will the same issue occur? You could double check if any library not being compiled also.
