Christian_Woznik
5 years agoPLL seperate design unit different between Quartus and Modelsim
Hello everyone,
I have yet another problem with Quartus and this time with Modelsim as well. In my design I use a PLL which I inserted via a Megawizard IP Core.
The problem is, that Quartus adds...
Ash_R_Altera
5 years agoHi
Why don't you create a NNFPGA_PLL library in Modelsim and compile the file in it? If you had generated the simulation environment from the Quartus, then it generates a msim_setup.tcl file that does the environment setup for you like compiling the files in required libraries.
