14 years agoPLL, Reconfigure, Qsys, Quartus 11.1, Stratix IV
Trying to instantiate a PLL and reconfiguration in Qsys.
Device is Stratix IV. Using Quartus 11.1. From Qsys, tried Avalon ALTPLL, Altera PLL Reconfig. Doesn't work, with errors shown below (during generation). Other observations that might help. - ALTPLL and ALTPLL RECONFIG seem to be available in Quartus megawizard. And in fact I got pll + reconfig to work in simulation, Stratix IV, Quartus only. - Altera PLL in Qsys only seems to want Stratix V. - Generally, there seems to be some disconnect between the Megawizard in Quartus and the available library items in Qsys. Error when generating Avalon ALTPLL in Qsys: Info: altpll_0: Error while generating PLL_playground_altpll_0.v : 1 : Illegal port or parameter name scandone Illegal port or parameter name scanclk Illegal port or parameter name scanclkena Illegal port or parameter name scandataout Illegal port or parameter name configupdate Illegal port or parameter name scandata child process exited abnormally Info: altpll_0: Illegal port or parameter name scandone Illegal port or parameter name scanclk Illegal port or parameter name scanclkena Illegal port or parameter name scandataout Illegal port or parameter name configupdate Illegal port or parameter name scandata child process exited abnormally while executing "exec clearbox altpll_avalon device_family=STRATIXIV CBX_FILE=PLL_playground_altpll_0.v -f cbxcmdln_1326246500574197" ("eval" body line 1) invoked from within "eval exec $cbx_cmd " Error: Can't continue processing -- expected file C:/Users/aschultz/AppData/Local/Temp/alt5350_5156334380085942516.dir/0006_sopcgen/PLL_playground_altpll_0.v is missing Warning: Quartus II 32-bit Generate HDL Interface was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 273 megabytes Error: Processing ended: Tue Jan 10 17:48:21 2012 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:01 Error: altpll_0: File C:/Users/aschultz/AppData/Local/Temp/alt5350_5156334380085942516.dir/0006_sopcgen/PLL_playground_altpll_0.v written by generation callback did not contain a module called PLL_playground_altpll_0 Info: altpll_0: "PLL_playground_inst" instantiated altpll "altpll_0" Error: Generation stopped, 1 or more modules remaining Info: PLL_playground_tb: Done PLL_playground_tb" with 9 modules, 21 files, 189442 bytes Error: ip-generate failed with exit code 1: 7 Errors, 2 Warnings Error: There were errors creating the testbench system. Info: Finished: Create testbench Qsys system
