16 years agoOk, new try without offset (for delay on PCB) and without derive_pll_clocks:
# ######################################### # clocks create_clock -name {clk1} -period 37.037 [get_ports {clk1}] create_clock -name {clk4} -period 37.037 [get_ports {clk4}] create_clock -name {clk8} -period 37.037 [get_ports {clk8}] # not needed right now # create_clock -name {clk12} -period 37.037 [get_ports {clk12}] # create_generated_clock -name {clk12_c0} -source [get_ports {clk12}] -multiply_by 4 [get_pins {inst4|altpll_component|pll|clk[0]}] create_generated_clock -name clk1_c2 -source [get_ports {clk1}] [get_pins {inst2|altpll_component|pll|clk[2]}] create_generated_clock -name clk4_c0 -source [get_ports {clk4}] [get_pins {inst3|altpll_component|pll|clk[0]}] create_generated_clock -name clk4_c2 -source [get_ports {clk4}] -phase 90.00 [get_pins {inst3|altpll_component|pll|clk[2]}] create_generated_clock -name clk8_c0 -source [get_ports {clk4}] -multiply_by 4 [get_pins {inst4|altpll_component|pll|clk[0]}] create_generated_clock -name clk8_c2 -source [get_ports {clk4}] -multiply_by 4 -phase -144.00 [get_pins {inst4|altpll_component|pll|clk[2]}] # ######################################### # slow asynchronous I/Os # reset set_false_path -from [get_ports {GDCRST}] ... # ######################################### # sdram ports set_input_delay -clock clk8_c2 -max 6.6 [get_ports {DQ[*]}] set_input_delay -clock clk8_c2 -min 3.4 [get_ports {DQ[*]}] set_output_delay -clock clk8_c2 -max 2.6 [get_ports {/CAS /RAS /WE /CS A[*] BA* CKE DQM* DQ*}] set_output_delay -clock clk8_c2 -min -0.6 [get_ports {/CAS /RAS /WE /CS A[*] BA* CKE DQM* DQ*}] # ######################################### Is this how you meant it? Clocks summary: clk1 -Base clk1_c2 - Generated clk4 -Base clk4_c0 - Generated clk4_c2 - Generated clk8 -Base clk8_c0 - Generated clk8_c2 - Generated report_sdc -ignored -panel_name "Ignored Constraints" Info: No ignored assignments to report But still: Illegal Clocks 0 Unconstrained Clocks 0 Unconstrained Input Ports 3 Unconstrained Input Port Paths 4 Unconstrained Output Ports 0 Unconstrained Output Port Paths 0 Unconstrained Input Ports: clk8 Unclocked clk4 Unclocked clk1 Unclocked Unconstrained Input Port Paths clk8 SCLK clk4 PIXCLKI clk4 PIXCLKI_n clk1 CLK_VGA And it doesn't matter, whether or not I add something like # ######################################### create_generated_clock -name sdram_clk_pin -source [get_pins {inst4|altpll_component|pll|clk[2]}] -offset 0.5 [get_ports {SCLK}] create_generated_clock -name pix_clk_pin -source [get_pins {inst3|altpll_component|pll|clk[2]}] -phase 90.00 -offset 0.5 [get_ports {PIXCLKI}] create_generated_clock -name pix_clk_pin_n -source [get_pins {inst3|altpll_component|pll|clk[2]}] -phase 90.00 -offset 0.5 [get_ports {PIXCLKI_n}] create_generated_clock -name clk_vga_pin -source [get_pins {inst2|altpll_component|pll|clk[2]}] -offset 0.5 [get_ports {CLK_VGA}] # ######################################### after that first 'create_generated_clock' block, to have something driving the SCLK, PIXCLKI etc. pll c2 outputs. What's wrong here?
