PLL input clock inclk[0] is not f ully compensated because it is fed by a remote clock pin
- 5 years ago
Hi Diego,
Please refer Figure 38 of Intel® Cyclone® 10 LP Core Fabric and General Purpose I/Os Handbook (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51003.pdf)
Each PLL has dedicated input pins, indicated by a solid line and dotted line. The solid line are the dedicated pins for that particular PLL. For example, PLL_1 has CLK[3:0]. However, PLL_1 can also be driven by other dedicated pins CLK[15:12}, but they are not associated ones for PLL_1.
Refer statement in section 4.2.4 "Input and output delays are fully compensated by the PLL only if you are using the
dedicated clock input pins associated with a given PLL as the clock sources."
To avoid the warning, use associated dedicated pins for the PLL.
Hi Diego,
Thanks for the response! That was what I was looking for.
