PLL constraint issues
- 2 years ago
No, you didn't have to break out the PLL output clocks like that. derive_pll_clocks is fine. I was referring to the 3 extra create_clock statements you have (sclk, clk_divider...). Those are coming from internal registers, not an input port of the device, so they should be in your .sdc as create_generated_clock commands, not create_clock.
As for the failing paths, those look like they are going to Signal Tap, which is debug logic that will be eventually removed. You don't really need to meet timing there.
The source is whatever clock or input pin that is driving the register or logic that produces the new clock. Think of it like a chain of cascading clocks. create_clock is only used for the start of the chain. Everything else is generated based on a previous clock.
- GreenLantern2 years ago
Hello sstrell,
Got it! This is excellent! Thank you so much for the help! I really appreciate it!
