GreenLantern's avatar
GreenLantern
2 years ago
PLL constraint issues
Getting this hold timing error. Need help resolving it. PLL cross checking found inconsistent PLL clock settings: Clock: i_DAC_TOP|i_PLL|pll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[...
  • sstrell's avatar
    2 years ago
    No, you didn't have to break out the PLL output clocks like that. derive_pll_clocks is fine. I was referring to the 3 extra create_clock statements you have (sclk, clk_divider...). Those are coming from internal registers, not an input port of the device, so they should be in your .sdc as create_generated_clock commands, not create_clock.
    As for the failing paths, those look like they are going to Signal Tap, which is debug logic that will be eventually removed. You don't really need to meet timing there.
Recent Discussions
