16 years agoI think, the messages are pretty clear. The respective PLL can be driven only by a routed clock (the PLL position is fixed most likely because if it's output connections or specific function, you didn't tell). It can't use one of it's associated clock inputs, so it has reduced timing compensation respectively jitter performance. In most cases it's no issue, simply accept it.
