10 years agoPlease solve this problem
write a procedure that assigns consecutive binary numbers to its OUT BIT_VECTOR lines.the parameters of the procedure are an 8-bit target output and a TIME period.When called, it will assign sequenti...
10 years agoNobody here is supposed to do your homework for you.
Write and post some code and then someone would possibly help in debugging it.
