Please help: Operation Failed when programming FPGA using .pof file
Try the pro edition programmer maybe?
That makes a difference for the stratix 10 for example,
pro is required, std is failing.
Also, maybe that your flash on board has an issue?
.sof is only programming the FPGA, not the flash.
- lixy3 years ago
Contributor
Hi AEsqu,
Regarding the version issue, the MAX 10 device is not supported by Quartus Pro edition. You can find out the FPGA devices' supported Quartus version from this link. https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html?wapkw=Quartus%20Device#intel%C2%AEmax%C2%AEseries
I agree with your idea about the FLASH issue. MAX 10 device contains internal FLASH memory, including Configuration FLASH memory and User FLASH memory. If SOF worked but POF failed, there's a possibility that the problem is in the internal FLASH memory inside of Quartus software.
Thanks & Regards,
Xiaoyan
