Envirosweet
3 years agoPlease help: Operation Failed when programming FPGA using .pof file
Encounter this Operation Failed issue when trying to program the FPGA using .pof file. Tried tick the Enable real-time ISP to allow background programming when available, then pop up a differe...
lixy
Contributor
3 years agoHi Envirosweet,
Which version of Programmer are you using?
In Intel FPGA Knowledge Database, there is a record of known issue that 10M02 device encounter "operation failed" error when programming the POF file. The solution is try to use Intel Programmer 19.1.
The device you are using is 10M04 according to your screenshot, please firstly try if this works.
https://www.intel.com/content/www/us/en/support/programmable/articles/000092639.html
Thanks & Regards,
Xiaoyan
- Envirosweet3 years ago
Hi Xiaoyan,
Thank you very much for your response.
I was using the version 23.1. And now I'm on version 19.1
However, the same issue still remains, .sof file works, but not .pof file.
Envirosweet
