Altera_ForumHonored Contributor14 years agoPlease help me How to set Global signal? Quartus II 9.1 design assistant said "Critical Warning: (High) Rule C105: Clock signal should be a global signal. (Value defined:25). Found 3 node(s) related to this rule." I turn off Auto Global Clo...Show More
Altera_ForumHonored Contributor14 years ago --- Quote Start --- What's the source of the clock signal? A pin? If so, is it a dedicated clock pin? --- Quote End --- It's a dedicated clock pin.
Recent DiscussionsQuartus Prime Lite 25.1 License Error - "Unable to checkout a license" (SALT_LICENSE_SERVER)Quartus Prime Pro 26.1 - Where to find Documentation of new Signaltap featuresError (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10Agilex 5 – Critical HSSI Error in JESD204B Example DesignQuartus did not start
