8 years agoPLEASE Help about Basic LED Blink
Hi, I'm beginner in VHDL, trying to get a true simulation result.
------------THIS'S THE CODE--------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity ensonled is port ( CLK_50MHz: in std_logic; myLED: out std_logic ); end ensonled; architecture ensonled of ensonled is signal counter:integer range 0 to 24999999; signal CLK_1Hz:std_logic :='0'; begin prescaler: process(CLK_50MHz) begin if rising_edge(CLK_50MHz) then if counter<25000000 then counter<=counter+1; else CLK_1Hz <= not CLK_1Hz; counter <= 0; end if; myLED<=CLK_1Hz; end if; end process prescaler; end ensonled; --------------------- THIS'S THE TEST BENCH CODE------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY ensonled_vhd_tst IS END ensonled_vhd_tst; ARCHITECTURE ensonled_arch OF ensonled_vhd_tst IS -- constants -- signals SIGNAL CLK_50MHz : STD_LOGIC; SIGNAL myLED : STD_LOGIC; COMPONENT ensonled PORT ( CLK_50MHz : IN STD_LOGIC; myLED : OUT STD_LOGIC ); END COMPONENT; BEGIN i1 : ensonled PORT MAP ( -- list connections between master ports and signals CLK_50MHz => CLK_50MHz, myLED => myLED ); --CLK_50MHz <= not CLK_50MHz after 20 ns/2; clk_gen_proc : process begin if CLK_50MHz /= '1' then CLK_50MHz <= '1'; else CLK_50MHz <= '0'; end if; wait for 20 ns; end process; END ensonled_arch; ----------------------------------- In simulation, I always getting 'myLED' as 0 after first rising edge of Clock. And additionally, for one time, I got a result like I desired, but whenever i tried it out over again, failed. Never changed the code, it was same. But it doesn't give a damn any more. Why? Please help me. https://alteraforum.com/forum/attachment.php?attachmentid=14932&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14932&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14932&stc=13 Replies
counter is always going to be less than 25000000 because you set its max range to 24999999.
ahh Thanks, though i've changed it, unfortunately giving same result:( what's wrong?
how long are you running the simulation for?
You need to run it for more than 500 ms for myLED to go high.
