13 years ago
please help !
i defined a port in the entity which is : distance : out integer ;
and i also defined a signal : signal echo_width : integer :=0;
i tried to assign multiplication by this way :
distance <= echo_width*(0.02/58);
and i got an error line :
"can't determine definition of operator ""*"" -- found 0 possible definitions"
what is the problem with my assignment and how should i resolve it ?
thank you about your responds.
    0.02 is a real, so you need to first cast the integers to reals, then back to integer:
    distance <= integer( real(echo_width) * (0.02 / 58.0) );
    But, remember that real types are not synthesisable, so I assume this is just testbench code.
    first of all - thank you very much for help !
    secondly - it is for synthesis , what can i do in this case ?
    so if its for synthesis - dont use real types. You can only use reals for set up information, not runtime arithmatic. Have a look into the fixed point packages.
    www.vhdl.org/fphdl
    is it synthesisable ?
    i defined an integer variable called "temp_distance" ,changed echo_width to a variable and used it like that :
    temp_distance:=integer(real(echo_width) * (0.02 / 58.0));
    distance<=temp_distance;
    reminder :
    distance : out integer ; (entity port)
    echo_width : variable integer;
    temp_distance: variable integer;
    Hi
    your output is integer so whatever the real data you get the decimal point digits will be truncated to integer
    so you have to find the nearest integer number to the real one
    for instance if we have the following operation:
    out = num * 0.05;
    you can find that 0.05 is nearly 13/256 (0.05078)
    so first multiply num by 13 and the division is simply removing the 8 digits from the right the right
    note that using integer is the same of std_logic_vector(31 downto 0) which is more flexible
    you can try this :
    signal num:std_logic_vector(31 downto 0);
    signal temp:std_logic_vector(35 downto 0);
    signal out1:std_logic_vector(31 downto 0);
    num <= x"0000028E"; -- test value 654
    temp<=num * x"d"; -- 654 * 13 = 8502
    out1 <= "00000000"&temp(31 downto 8);-- 8502 / 256 = 33
    this result 33 is near to 654 * 0.05 = 32.7
    this what I do to deal with float numbers
    did you got it?
