Nitin1's avatar
Nitin1
5 years ago
Platform Designer Error
I am getting this error when trying to Generate files using Quartus Standatd Edition version
Error: add_fileset_file: No such file C:/Users/nmistry/AppData/Local/Temp/alt8839_8898266765451528108.dir/0006_cpu_gen/simgen_tmp_0
while executing
"add_fileset_file "$file_name" OTHER PATH "$my_file""
(procedure "sub_add_generated_files" line 51)
invoked from within
"sub_add_generated_files "$NAME" "$output_directory" "$rtl_ext" "$simgen" "$plainTEXTfound""
(procedure "generate_with_plaintext" line 6)
invoked from within
"generate_with_plaintext "$NAME" "$rtl_ext" "$simgen""
(procedure "sub_sim_verilog" line 5)
invoked from within
"sub_sim_verilog niosii_system_nios2_cpu"
This error only started today and was not occuring before with this design
  • sstrell's avatar
    sstrell
    Delete the directory named after the system and try to generate again.
  • sstrell's avatar
    sstrell
    Your published output directory may be corrupted. Keep the .qsys file and all other main files in your project directory and delete the folder generated by Platform Designer that has the same name as your system. Then try to regenerate the system.
  • Nurina's avatar
    Nurina
    Did the above reply solve your problem?
