9 years agoPlacement cannot find a legal solution
Hi, I am targeting the a10gx using AOC and Quartus Prime, both v16.1.2 Build 203. According to the logs my design is not overutilizing resources, but the building process fails during fitt...
9 years agoHi HRZ,
Thanks you for checking the log files! --- Quote Start --- ... However, as I also mentioned in the other thread, these numbers seem to overflow in cases where utilization goes over 100%. What do you get from aoc's resource estimation? If the logic utilization you get is over 80%, my guess is that you are running out of logic, even though that would be very rare/strange on Arria 10. --- Quote End --- This is the logic estimation I got using aoc: +--------------------------------------------------------------------+ ; Estimated Resource Usage Summary ; +----------------------------------------+---------------------------+ ; Resource + Usage ; +----------------------------------------+---------------------------+ ; Logic utilization ; 64% ; ; ALUTs ; 31% ; ; Dedicated logic registers ; 34% ; ; Memory blocks ; 67% ; ; DSP blocks ; 44% ; +----------------------------------------+---------------------------; All numbers are under 80% so no idea what could be wrong ...
