15 years agoPiplining, what is the best way?
I have an algorithm that takes input data, make several sequental steps, and deliver results. Since my input data is comming very fast, I need to pipeline my computations. I have test example created similar to my problem and need kind help. My test example is attached. It contains 2 different always blocks controlled with Clk1 and Clk2. I am sure that Clk2 is ok and do what I want. My question is the following, is the "always" block with Clk1 is correct, or can be modified to achieve better timing properties? Thank you! Sincerely, Ilghiz
module My_Second_Project (A1, A2, A3, Clk1, Clk2, X1, X2, X3, Y1, Y2, Y3);
input A1, A2, A3;
input Clk1, Clk2;
output X1, X2, X3;
reg X1, X2, X3;
output Y1, Y2, Y3;
reg Y1, Y2, Y3;
reg B1, B2, B3, C1, C2, C3;
reg P1, P2, P3, Q1, Q2, Q3, R1, R2, R3, S1, S2, S3;
always @(posedge Clk1)
// can I ensure that I read C1,C2,C3 first for computations of X1,X2,X3,
// and the same for other variables? When I change all "=" to "<="
// I have no difference in RTL!!!
begin
X1=C1*C2;
X2=C1*C3;
X3=C2*C3;
C1=B1*B2;
C2=B1*B3;
C3=B2*B3;
B1=A1*A2;
B2=A1*A3;
B3=A2*A3;
end
always @(posedge Clk2)
// is Ok, have 3 pipe-line blocks
begin
Y1=S1*S2;
Y2=S1*S3;
Y3=S2*S3;
R1=Q1*Q2;
R2=Q1*Q3;
R3=Q2*Q3;
P1=A1*A2;
P2=A1*A3;
P3=A2*A3;
end
always @(negedge Clk2)
begin
Q1=P1;
Q2=P2;
Q3=P3;
S1=R1;
S2=R2;
S3=R3;
end
endmodule
