11 years ago#pipeline stages after using aoc to generate the report ?
Hi , Is there any report showing how many pipeline stages / stall clocks (using NDRrange - Multi-threads) by using aoc command ? Thanks.
11 years agoSearching in the forum I found out this old post (http://www.alteraforum.com/forum/showthread.php?t=41198) where it's said that:
--- Quote Start --- The use model of the OpenCL compiler is that you don't need to worry about the pipeline depth because it will already be tuned to ensure that enough work-items are in flight to keep the pipeline full. --- Quote End --- But still, I think it would be nice to have some info about the pipeline.
