11 years ago#pipeline stages after using aoc to generate the report ?
Hi , Is there any report showing how many pipeline stages / stall clocks (using NDRrange - Multi-threads) by using aoc command ? Thanks.
11 years agoHi there,
I'm trying as well to understand how to get this information. Using the instructions above I opened Quartus II and then using file->open project to select the wished top.qpf file. At this point I had a screen like the one posted by vsenicourt. After that, using the menu Tools, netlist viewers->rtl viewers showed me a new window like the one in the image attached but I could get the number of stages in the pipeline. The project I'm using is the Fast Fourier Transform OpenCL Design Example from Altera which launches a single work item hence enqueues a task.
