11 years ago#pipeline stages after using aoc to generate the report ?
Hi , Is there any report showing how many pipeline stages / stall clocks (using NDRrange - Multi-threads) by using aoc command ? Thanks.
11 years agoThe reports that altera provides are very limited. The optimization report in <kernel>/<kernel>.log contains some optimization reports but not a lot that occasionally shows inferred pipeline stages when you build the .aocx. You can check stalls/occupancy and bandwidth of memory access by running the profiler when you compile the kernel with --profile.
