10 years agoPIO (already defined in Qsys) not found in schematic !!
Hello I am using Quartus 13.0 web edition.. After creating my Qsys, which contains PIO LED and SW, I am supposed to assign PINS. The problem is that only clk and reset pins appear during chip p...
10 years ago --- Quote Start --- I guess you have to expose the PIO connections. Click on the 'conduit' line : if I remember correctly Qsys will ask you to export the signals and the name to assign to. Then the pins will appear on the Qsys device block --- Quote End --- Thnx it worked well
