10 years agoPIO (already defined in Qsys) not found in schematic !!
Hello I am using Quartus 13.0 web edition.. After creating my Qsys, which contains PIO LED and SW, I am supposed to assign PINS. The problem is that only clk and reset pins appear during chip p...
10 years agoI guess you have to expose the PIO connections. Click on the 'conduit' line : if I remember correctly Qsys will ask you to export the signals and the name to assign to. Then the pins will appear on the Qsys device block
