8 years agoPinconfig of the FPGA to HPS. Some eroors in IOBUF
I wanted to drive the bidirectional signals from fpga to hps and hps to fpga. But I could not able to do with my code here. Please have a look my code and give me some tips. THIS CODE IS WORKING PERFECTLY, bUT IT WORKS FOR ONLY ONE DIRECTION, i WANTED TO SEE BIDIRECTIONAL RESPONCE FOR THAT I NEED TO USE IOBUF COMPONENT. I HAVE NO IDEA HOW TO IMPLEMENT THAT COMPONENT IN MY CODE. PLEASE HAVE ALOOK AND HELP ME. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity pinconfig is port( pins :in std_logic_vector (13 downto 0):="00000000000000"; signalsin :inout std_logic_vector (35 downto 0); signalsout :inout std_logic_vector (35 downto 0) ); end pinconfig; architecture behav of pinconfig is component iobuffer PORT ( datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0); oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0); bidir : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0); dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0) ); end component; type c is array (0 to 35, 0 to 2) of integer range 0 to 35; signal config : c := ((0,0,0),(1,1,0),(2,2,0),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), (12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), (24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3)); --config(x,x,0) = out (fpga => gpio) --config(x,x,1) = in (fpga <= gpio) --config(x,x,2) = constant low (pin) --config(x,x,3) = high-Z (pin) signal temp: std_logic_vector (35 downto 0); begin process (pins) begin --pins(13 downto 8) = mapped to --pins(7 downto 2) = mapped from --pins(1 downto 0) = out, in or high-Z config(to_integer(unsigned(pins(13 downto 8))),1) <= to_integer(unsigned(pins(7 downto 2))); config(to_integer(unsigned(pins(13 downto 8))),2) <= to_integer(unsigned(pins(1 downto 0))); end process; process (signalsin, signalsout) begin case config(0,2) is when 0 => temp(config(0,0)) <= signalsin(config(0,1)); when 1 => temp(config(0,1)) <= signalsout(config(0,0)); when others => end case; case config(1,2) is when 0 => temp(config(1,0)) <= signalsin(config(1,1)); when 1 => temp(config(1,1)) <= signalsout(config(1,0)); when others => end case; case config(2,2) is when 0 => temp(config(2,0)) <= signalsin(config(2,1)); when 1 => temp(config(2,1)) <= signalsout(config(2,0)); when others => end case; case config(3,2) is when 0 => temp(config(3,0)) <= signalsin(config(3,1)); when 1 => temp(config(3,1)) <= signalsout(config(3,0)); when others => end case; case config(4,2) is when 0 => temp(config(4,0)) <= signalsin(config(4,1)); when 1 => temp(config(4,1)) <= signalsout(config(4,0)); when others => end case; ** LIKE 36 PINS I WROTE CODE** end process; process (temp) begin case config(0,2) is when 0 => signalsout(config(0,0)) <= temp(config(0,0)); when 1 => signalsin(config(0,1)) <= temp(config(0,1)); when 2 => signalsout(config(0,0)) <= '0'; when others => signalsout(config(0,0)) <= 'Z'; end case;case config(1,2) is when 0 => signalsout(config(1,0)) <= temp(config(1,0)); when 1 => signalsin(config(1,1)) <= temp(config(1,1)); when 2 => signalsout(config(1,0)) <= '0'; when others => signalsout(config(1,0)) <= 'Z'; end case;case config(2,2) is when 0 => signalsout(config(2,0)) <= temp(config(2,0)); when 1 => signalsin(config(2,1)) <= temp(config(2,1)); when 2 => signalsout(config(2,0)) <= '0'; when others => signalsout(config(2,0)) <= 'Z'; end case;case config(3,2) is when 0 => signalsout(config(3,0)) <= temp(config(3,0)); when 1 => signalsin(config(3,1)) <= temp(config(3,1)); when 2 => signalsout(config(3,0)) <= '0'; when others => signalsout(config(3,0)) <= 'Z'; end case;case config(4,2) is when 0 => signalsout(config(4,0)) <= temp(config(4,0)); when 1 => signalsin(config(4,1)) <= temp(config(4,1)); when 2 => signalsout(config(4,0)) <= '0'; when others => signalsout(config(4,0)) <= 'Z'; ** HERE ALSO SAME LIKE 36 PINS CODE** end case; end process; end behav; ** See in attached file for normal response and input force response and output force response **1 Reply
Are you referring to signals inside your SoC device? You want to change the direction of both processor I/O and fabric I/O, across the internal HPS/Fabric boundary, within the device? I'm not convinced this is possible.
The processor has standard interfaces for interfacing to the fabric - an AMBA AXI interface (the HPS-to-FPGA bridge). Cheers, Alex
