11 years agoPin "x" is stuck at GND
This should be really simple. I'm new at this. Why do I get a compile message, "output stuck at ground"? I just want to generate a stretched pulse when I get a nWR low edge. module Extend...
11 years ago --- Quote Start --- Time delays (#) are not synthesisable. The last assignment is 0, hence stuck at ground. If you want a stretch pulse, you need to use a counter. --- Quote End --- Thanks! Will search/post separately asking for leads on good basic info, like what is sythesizable. Am interested in good starting points - I'm an EE with lots of embedded experience and just starting FPGA. Amazed at how little good practical instruction there is online.
