11 years agoPin "x" is stuck at GND
This should be really simple. I'm new at this. Why do I get a compile message, "output stuck at ground"? I just want to generate a stretched pulse when I get a nWR low edge. module Extend...
11 years agoTime delays (#) are not synthesisable. The last assignment is 0, hence stuck at ground. If you want a stretch pulse, you need to use a counter.
