JBlac1
8 years agoPin Planner: This is a read-only item
I am a new to FPGA design, I am now playing a simple LED flow example. I am using Quartus 15.1 and Cyclone V. I firstly write a verilog code and then go to setup the pins. In the Pin Planner, for ...
CalvinJoaz_P_Intel
Contributor
8 years agoHi JBlac1,
Sstreal is correct! Need to have blackbox module or entity with ports or IO's declared. So that, you can see the direction's in the pin assignments.
Your design file is the input for the Pin Planner.
