Pin Planner Bug - has it been fixed yet?
- 6 years ago
i see, in that case, we will close thread. You can open a new thread once you have time to work on it. Is that fine?
I don't think I've ever seen this, but you could just double-click (or maybe triple-click because double-click brings up the pop-up list) the Location field and type in the pin number instead of using the pop-up lists.
- SparkyNZ6 years ago
Contributor
I didn't realise you could triple click
I'll see how that behaves. I suspect it's when I click onto another row (after modifying the pin location) that things sometimes go wrong. But I really do need to try that latest Quartus version. Once I get my current project sorted, I'll take the plunge. Thanks - SparkyNZ6 years ago
Contributor
I have installed the latest Quartus (version 20). May be a while before I use the pin planner again but I'll be sure to keep an eye on it and update this thread with my findings.
