10 years agopin number already assigned to a node
Hi, i try to use pin planner for the first time. I want to assign an output to a specific pin , however this is not possible because this pin is already assigned to a 'node' in the list. H...
10 years agoHi,
Sorry for the small image , i thought it would show bigger. So those 'nodes' with ? where by default inserted in the list (i did not make the project from scratch). Some of the pins locations that i needed where occupied by those nodes (maybe by default?) so i removed the pin location from those and put them in my 'real' output pins. I did not remove the nodes but then the fitter issued warnings that those nodes where removed because they did not exist in the design. thanks for your help!
