9 years agoPin assignment does not show in graphic editor of Quartus II 16.1
Hello ! I have a strange problem: when I assign pin location to an input or output pin, it works but the assignment does not show in graphic editor. I can swithch on or off in (right click) Sho...
FCasa3
7 years agoHi. I have suffered just the same problem. The problem is due to the fact that leyend does not fit into the box for the pin number. You two options for solving it:
1.- The tedious one: Go pin by pin enlarging the box devoted to show the pin number
2.- The easy one: Go to Tools menu, select Options… and then select Fonts in the Block/Symbol Editor (in the left pane). On the right pane a box labeled Types of text will appear. Select Mapper & block I/O table text, and in the size selection pane below, choose a smaller font size. In my case I changed it from 8 to 7 and the pin numbers appeared again
