8 years agopi controller i verilog
i used matlab hdl coder to design the pi controller. but when I use it an error occurs
it shows $bitstoreal is not supported 2 real value is not supported. any help thanku // ------------------------------------------------------------- // // File Name: hdlsrc\untitled\PI_Controller.v // Created: 2018-02-27 12:02:47 // // Generated by MATLAB 9.0 and HDL Coder 3.8 // // ------------------------------------------------------------- // ------------------------------------------------------------- // // Module: PI_Controller // Source Path: untitled/PI Controller // Hierarchy Level: 1 // // ------------------------------------------------------------- `timescale 1 ns / 1 ns module PI_Controller ( clk, reset, enb, u, y ); input clk; input reset; input enb; input [63:0] u; // double output [63:0] y; // double real u_double; // double real Proportional_Gain_out1; // double real Integral_Gain_out1; // double real Integrator_x_reg; // double real Integrator_u_add; // double real Sum_out1; // double always @* u_double = $bitstoreal(u); always @* Proportional_Gain_out1 = 0.0349 * u_double; always @* Integral_Gain_out1 = 2.0 * u_double; always @* Integrator_u_add = Integrator_x_reg + Integral_Gain_out1; always @(posedge clk or posedge reset) begin : Integrator_reg_process if (reset == 1'b1) begin Integrator_x_reg <= 0.0; end else begin if (enb) begin Integrator_x_reg <= Integrator_u_add; end end end always @* Sum_out1 = Proportional_Gain_out1 + Integrator_x_reg; assign y = $realtobits(Sum_out1); endmodule // PI_Controller1 Reply
The model below is not synthesizable.
$real is not supported in synthesis. Additionally, most of the logic is not synchronous. Perhaps the HDL compiler from MathWorks is only generating a simulation model, not a synthesizable one. -James --- Quote Start --- i used matlab hdl coder to design the pi controller. but when I use it an error occurs it shows $bitstoreal is not supported 2 real value is not supported. any help thanku // ------------------------------------------------------------- // // File Name: hdlsrc\untitled\PI_Controller.v // Created: 2018-02-27 12:02:47 // // Generated by MATLAB 9.0 and HDL Coder 3.8 // // ------------------------------------------------------------- // ------------------------------------------------------------- // // Module: PI_Controller // Source Path: untitled/PI Controller // Hierarchy Level: 1 // // ------------------------------------------------------------- `timescale 1 ns / 1 ns module PI_Controller ( clk, reset, enb, u, y ); input clk; input reset; input enb; input [63:0] u; // double output [63:0] y; // double real u_double; // double real Proportional_Gain_out1; // double real Integral_Gain_out1; // double real Integrator_x_reg; // double real Integrator_u_add; // double real Sum_out1; // double always @* u_double = $bitstoreal(u); always @* Proportional_Gain_out1 = 0.0349 * u_double; always @* Integral_Gain_out1 = 2.0 * u_double; always @* Integrator_u_add = Integrator_x_reg + Integral_Gain_out1; always @(posedge clk or posedge reset) begin : Integrator_reg_process if (reset == 1'b1) begin Integrator_x_reg <= 0.0; end else begin if (enb) begin Integrator_x_reg <= Integrator_u_add; end end end always @* Sum_out1 = Proportional_Gain_out1 + Integrator_x_reg; assign y = $realtobits(Sum_out1); endmodule // PI_Controller --- Quote End ---
