15 years agoPhase lock loop
I want to implement a phase lock loop in fpga , altera(cyclone II). The internal clock is 50 MHZ. but my input clock is 60 HZ. How i should implement pll in this case???
My output should be same as input(60 HZ). But fpga has in built pll, whose internal clock works at Mhz. So Hz and Mhz cant be synchronized.
I was trying to implement in zero buffer mode using a[/U][/U]ltpll megafunction But its input range is in MHz. It is possible for me to implement in fpga reconfig methods.
