15 years agoPhase lock loop
I want to implement a phase lock loop in fpga , altera(cyclone II). The internal clock is 50 MHZ. but my input clock is 60 HZ. How i should implement pll in this case???
You didn't mention the intended output of the PLL (frequency, waveform). In power electronic applications, a 50/60 Hz PLL with quadrature sine output is a common building block. It can be implemented with a NCO, phase detector (multiplier with averager/integrator) and a PI controller. In contrast to the high frequency analog PLL provided for FPGA clocking, the complete PLL function is performed by digital signal processing. Thus it's called digital or all digital PLL (DPLL/ADPLL).
