sakrin
5 years agopeak wire utilization 100% over
After compiling a design, I looked at the Global Router Wire Utilization Map and saw that some of the utilization exceeded 100%. However, it seems that bitstreams are being generated.
Does this bit...
- 5 years ago
The Global Router Wire Utilization Map gives a visual representation of estimated wire usage on the chip and give detailed information about what might be causing the route congestion.
Unless there is a fitter error saying unsuccessful, it should Not impact the bitstream generated once compilation passed.
RichardT_altera
5 years agoThe Global Router Wire Utilization Map gives a visual representation of estimated wire usage on the chip and give detailed information about what might be causing the route congestion.
- sakrin5 years ago
I understand now, thanks to you!
