PCIe HIP clocking regression on Stratix 10 MX in Quartus Prime Pro 22.2
- I wasn't referencing a user guide, I just deleted the core and created a new one from the IP library, configuring the appropriate settings in the parameter editor. Originally, the core was created via TCL, which was exported from the parameter editor in a previous version of Quartus. I recreated it manually to rule out any issues in the exported TCL.
- It's the AVST core
- I suspect that the issue will appear in the AVST example design. But, I just did some quick testing, and it's also a problem on the 8 lane, 256 bit configuration of the same core, and that design is available here: https://github.com/corundum/corundum/tree/master/fpga/mqnic/S10MX_DK/fpga_10g
Edit: Actually, this design is simpler, and exhibits the same problem: https://github.com/alexforencich/verilog-pcie/tree/master/example/S10MX_DK/fpga
Hi Alex,
Did you try out either H-Tile AVMM/DMA example release by Intel ?
Is it behave the same? Just want to ensure it only happen in AVST or all PCIe related example in 22.2
Looking forward to hear back from you.
Wincent_C_Intel
- alexforencich4 years ago
I have not tested any of the other cores, as my design uses the AVST version with a custom DMA engine. Have you been able to replicate the issue in the example designs that Quartus can generate for the PCIe IP cores?
- Wincent_Altera4 years ago
Hi Alex,
Apologize for the late reply, I had some problems in navigating your design in Github link provided.
Is it possible for you to attach your .qar file here ?
Looking forward to hear back from you soon.Regards,
Wincent_C_Intel
The problem is not reproducible in the PCIe AVST example design?
