12 years ago
PCIe-385N board factory flash load 13.1
The Nallatech factory flash configuration can be reloaded to the PCIe-385N for Altera OpenCL 13.1 with the appropriate flash file below by running the "aocl flash pcie385n_a7_factory.aocx" command (or "aocl flash pcie385n_d5_factory.aocx").
G
    --- Quote Start ---
    G
    --- Quote End ---
    Hi gigi,
    Thanks for the package. Is this the default hardware image burnt into the flash, just want to make sure. I was trying to figure out a problem. I downloaded Hello_Wolrd sample code package for 13.1 for Altera Web. I burnt the hello_world_131_pcie385n_a7.aocx they provide and powered off my computer and restarted. When I run ./hello_world after run make -f makefile. It failed.
    fpga is in user mode. enabling bridges
    querying platform for info:
    cl_platform_name = altera sdk for opencl
    cl_platform_vendor = altera corporation
    cl_platform_version = opencl 1.0 altera sdk for opencl, version 13.1
    error: cl_device_not_found
    query for number of devices failed
    Also, same case if I burnt hello_world.aocx I compiled by myself.
    More hint. When I run aocl diagnostic
    aocl diagnostic: running diagnostic from /home/jisuansuogcb/altera/13.1/hld/board/pcie385n/linux64/bin
    running diagnostic for : acl0
    using platform: altera sdk for opencl
    failed clgetdeviceids.
    error code: -1
    aocl diagnostic: failed.
    But when I run aocl install, it is done.
    aocl install: running install from /home/jisuansuogcb/altera/13.1/hld/board/pcie385n/linux64/bin
    using kernel source files from /usr/src/kernels/2.6.18-274.el5xen-x86_64
    make: entering directory `/usr/src/kernels/2.6.18-274.el5-xen-x86_64'
    building modules, stage 2.
    modpost
    make: leaving directory `/usr/src/kernels/2.6.18-274.el5-xen-x86_64'
    It seems like some problem with PCIe. But aocl diagnostic was successful before I burnt aocx into flash. So I am afraid if I ruint PCIe drivers in ROM and am thinking about burnt the default hardware image back. Thank!!
    Hi hangyuxuan19910802,
    If your board was functioning before you updated the flash with a design you compiled yourself, I would think that maybe the flash update was not successful or the aocx file was somehow invalid.
    Depending on the board you have (A7 or D5), I would reprogram the flash with the factory design for 13.1 I previously posted using the "aocl flash <design>.aocx" command. Once you have done that, power down your system fully (not only reboot) and power it back up. Then check if you can do "aocl diagnostic" again.
    G
    --- Quote Start ---
    G
    --- Quote End ---
    Thank you gigi!!
    I tried the aocx your provided in your opencl_13.1_a7_factory.zip (http://www.alteraforum.com/forum/attachment.php?attachmentid=8813&d=1398896333). After cool reboot, it did work when I run $aocl diagnostic and I could see the communication information. But, when I burnt the hello_world.aocx again, it crashed as before. Some hint is when I ran this one $lspci | grep Altera, there was no output. Does it probably mean something wrong with pcie driver installation? I am using pcie_385n_a7. Am i missing some steps in between? Thanks!
    --Yuxuan
    --- Quote Start ---
    G
    --- Quote End ---
    Thank you, gigi!!
    I burnt factory image pcie385n_a7_factory.aocx from this post. It worked and I saw my a7 board can communicate with host machine through pcie, when I ran $ aocl diagnostic. Then I burnt hello_world.aocx again. After cold reboot the host machine, it crashed and showed the same information as before when I ran $ aocl diagnostic.
    error code: -1
    Something I am not sure is that when I ran $lspci | grep alter, there was no output, probably meaning board driver installation failure, according to get_started documents. As for the board driver installation, since I am using pcie 385n a7 board, I just ran $aocl install, the result was
    modpost
    That means, as I understand, the driver was compiled successfully. And do I have to run any other commands for the driver installation? Or am I missing some processes before I run ./hello_world on host side? Another question is what does the factory hardware image .aocx do? If I burnt hello_world instead, and the default one should be erased, as I understand, the program of the default image which makes communication between board and host successful will be erased too,right?
    Thanks!!
    Yuxuan
    Hi Yuxuan,
    if you run "aocl flash hello_world.aocx" (your design) after you have run "aocl flash pcie385n_a7_factory.aocx" your design will overwrite the factory image.
    As you have managed to regain access to your board when going back to the factory design it confirms your design is somehow wrong and that the board itself is working as expected.
    Maybe you compiled it for a D5 board instead of an A7?
    You do not need to update your flash if you are only using 13.1; you only need to update your flash if you are updating to 14.0.
    G
    --- Quote Start ---
    Hi Yuxuan,
    G
    --- Quote End ---
    Thank you. It is not working. I think you are right there's problem with the design.aocx. But I am sure I am using A7 board since I can get information from JTAG and also your a7 factory image works for my board. When I burnt the flash with the design, it failed. But after that, I flashed back to factory image and ran $./hello world...it showed :
    ./hello_world
    querying device for info:
    cl_device_name = pcie385n_a7 : pcie-385n altera stratix v computing card
    cl_device_vendor = nallatech inc.
    cl_device_vendor_id = 4466
    cl_device_version = opencl 1.0 altera sdk for opencl, version 13.1
    cl_driver_version = 13.1
    cl_device_address_bits = 64
    cl_device_available = true
    cl_device_endian_little = true
    cl_device_global_mem_cache_size = 32768
    cl_device_global_mem_cacheline_size = 0
    cl_device_global_mem_size = 4294967296
    cl_device_image_support = false
    cl_device_local_mem_size = 16384
    cl_device_max_clock_frequency = 1000
    cl_device_max_compute_units = 1
    cl_device_max_constant_args = 8
    cl_device_max_constant_buffer_size = 1073741824
    cl_device_max_work_item_dimensions = 3
    cl_device_max_work_item_dimensions = 1024
    cl_device_min_data_type_align_size = 128
    cl_device_preferred_vector_width_char = 4
    cl_device_preferred_vector_width_short = 2
    cl_device_preferred_vector_width_int = 1
    cl_device_preferred_vector_width_long = 1
    cl_device_preferred_vector_width_float = 1
    cl_device_preferred_vector_width_double = 0
    command queue out of order? = false
    command queue profiling enabled? = true
    using aocx: hello_world_131_pcie385n_a7.aocx
    cvp failed
    cvp failed
    kernel initialization is complete.
    launching the kernel...
    thread# 2: hello from altera's opencl compiler!
    CvP failed, but *hello world* is printed. How can I interpret this? Thanks so much.
    yuxuan
