11 years agoPCI driver for DE5-net board on Windows7
I am trying to install DE5-net board from Terasic on windows 7. I followed the instructions on Altera OpenCL getting started guide and the OpenCL guide by terasic. If I run the "aocl install" com...
11 years agoI did copy the dll now. Still the similar error.
If I run the "aocl diagnose" or "aocl diagnose acl0", I get the following error C:\altera\14.1\hld\board\terasic\tests\hello_world>aocl diagnose aocl diagnose: Running diagnostic from C:\altera\14.1\hld\board\terasic\de5net/w indows64/libexec Verified that the kernel mode driver is installed on the host machine. Using board package from vendor: Terasic Technologies Querying information for all supported devices that are installed on the host ma chine ... MMD ERROR: failed to scan for the PCI device. Found no active device installed on the host machine. Please make sure to: 1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct boa rd package. 2. Install the driver from the selected board package. 3. Properly install the device in the host machine. 4. Configure the device with a supported OpenCL design. 5. Reboot the machine if the PCI Express link failed. DIAGNOSTIC_FAILED C:\altera\14.1\hld\board\terasic\tests\hello_world>aocl diagnose acl0 aocl diagnose: Running diagnostic from C:\altera\14.1\hld\board\terasic\de5net/w indows64/libexec Verified that the kernel mode driver is installed on the host machine. MMD ERROR: failed to scan for the PCI device. Using platform: Altera SDK for OpenCL Failed clGetDeviceIDs. Error code: -1 Verified that the kernel mode driver is installed on the host machine. MMD ERROR: failed to scan for the PCI device. Using platform: Altera SDK for OpenCL Failed clGetDeviceIDs. Error code: -1 aocl diagnose: failed. I get this error if I try to run aocl install now. Earlier it was not able to find the device: +------------------------------------------------------+ + Installing kernel driver module... + +------------------------------------------------------+ WDREG utility v11.00. Build Feb 27 2012 14:45:04 Processing HWID *WINDRVR6 Installing a signed driver package for *WINDRVR6 CM_Get_DevNode_Status ret value 0, status 180200b, problem 0 LOG ok: 1, ENTER: DriverPackageInstallA LOG ok: 1, ENTER: DriverPackageInstallW LOG ok: 1, Looking for Model Section [DeviceList.NTamd64]... LOG ok: 1, Installing INF file 'C:\altera\14.1\hld\board\terasic\de5net\windows6 4\driver\windrvr6.inf' (Plug and Play). LOG ok: 1, Looking for Model Section [DeviceList.NTamd64]... LOG ok: 1, Installing devices with Id "*WINDRVR6" using INF "C:\Windows\System32 \DriverStore\FileRepository\windrvr6.inf_amd64_neutral_c28ab21bf526a086\windrvr6 .inf". LOG ok: 1, Will force install because driver is not better and force flag is set . LOG ok: 1, ENTER UpdateDriverForPlugAndPlayDevices... LOG ok: 0, RETURN UpdateDriverForPlugAndPlayDevices. LOG ok: 1, Installation was successful. LOG ok: 0, Install completed LOG ok: 1, RETURN: DriverPackageInstallW (0x0) LOG ok: 1, RETURN: DriverPackageInstallA (0x0) difx_install_preinstall_inf: err 0, last event 0, last error 0. SUCCESS install: completed successfully +------------------------------------------------------+ + Installing board drivers... + +------------------------------------------------------+ WDREG utility v11.00. Build Feb 27 2012 14:45:04 Processing HWID PCI\VEN_1172&DEV_AB00&SUBSYS_00041172&REV_01 Installing a non-signed driver package for PCI\VEN_1172&DEV_AB00&SUBSYS_00041172 &REV_01 Device node (hwid:PCI\VEN_1172&DEV_AB00&SUBSYS_00041172&REV_01): exists and is c onfigured. Installing. Error: Failed to install the INF file (C:\altera\14.1\hld\board\terasic\de5net\w indows64\driver\acl_boards.inf) CM_Get_DevNode_Status ret value 0, status 1802400, problem 1c LOG ok: 1, ENTER: DriverPackageInstallA LOG ok: 1, ENTER: DriverPackageInstallW LOG ok: 2, DRIVER_PACKAGE_LEGACY_MODE flag set but not supported on Plug and Pla y driver on VISTA. Flag will be ignored. LOG ok: 1, Looking for Model Section [DeviceList.NTamd64]... LOG ok: 1, Installing INF file 'C:\altera\14.1\hld\board\terasic\de5net\windows6 4\driver\acl_boards.inf' (Plug and Play). LOG ok: 1, Looking for Model Section [DeviceList.NTamd64]... LOG ok: 1, Installing devices with Id "PCI\VEN_1172&DEV_AB00&SUBSYS_00041172&REV _01" using INF "C:\Windows\System32\DriverStore\FileRepository\acl_boards.inf_am d64_neutral_3393fe1978a41ba4\acl_boards.inf". LOG ok: 1, ENTER UpdateDriverForPlugAndPlayDevices... LOG ERROR(3): error e0000206, RETURN UpdateDriverForPlugAndPlayDevices. LOG ERROR(3): error e0000206, Installation failed. LOG ERROR(3): error e0000206, PnP Install failed. LOG ok: 1, Attempting to rollback ... LOG ok: 1, No devices to rollback LOG ok: 1, RETURN: DriverPackageInstallW (0xE0000206) LOG ok: 1, RETURN: DriverPackageInstallA (0xE0000206) difx_install_preinstall_inf: err e0000206, last event 3, last error e0000206. U NKNOWN Error: Failed trying to install the driver aocl install: failed. ---------------------------------------------------------------------- Thank you for your reply.
