passing value to tcl
- 5 years ago
thx. seem "exec" would work but everytime i try
exec quartus_sh -t top.tcl 5 it just freeze quartus
May I know whether the suggestion from Heiko help in your case?
Do you need further help on this?
Richard Tan
it help on linux side, but what about tcl console in quartus?
when i try quartus_sh i got these errors
Error:invalid command name "quartus_sh"
- Heiko5 years ago
If you're running it from the tcl console the quartus_sh is not a valid command. Because (*I think) the tcl console in the quartus user interface is actually just the quartus_sh executable running in interactive mode.
To call quartus_sh from the tcl console you could use the exec command.
Following your example
exec quartus_sh -t top_all.tcl 5
Not sure if that is the most elegant solution to your problem. But it should work.
- s002wjh5 years ago
- RichardT_altera5 years ago
You may need to run it using command prompt. For best results, run shell commands and Intel® Quartus® Prime executables from a system command prompt outside of the Intel® Quartus® Prime software GUI.
Richard Tan
